2 members (Bill Hanlon, 1 invisible),
131
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95268 04/02/2006 4:03 PM | Joined: Jan 2006 Posts: 8 New Guy | | New Guy Joined: Jan 2006 Posts: 8 | What are the components necessary to convert a 52 Chevy PU from 6 volt to 12 volt?
Thanks | | |
#95269 04/02/2006 4:52 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 12 volt bat., gen-reg or alt-reg.,all light bulbs. Coil & resister. Starter switch with bypass. Resister for gas gauge (see posts nearby).12volt heater motor or resister,. Radio.Turn signal flasher. If i,ve left anything out fellow bolters help out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95270 04/02/2006 6:38 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | spyder68, Just in case you have not yet checked out the Tech Section of this site (see Tech Tips at the top of this apge), here is the 12 volt conversion Tech Tip. The EL110 resistor that is listed at the bottom of that page might not be a Runtz resistor , which is recommended by many (but not all) people. Tim | | |
#95271 04/03/2006 4:30 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | You might want to get a copy of The Offical 12-Volt Conversion Guide from Fifth Avenue or Speedway Motors. The book is a step by step guide and explains everything you need to do to get it righ the first time.....Randy | | |
