1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | I just happened upon this on my 235 during a gasket change. The rods don't look damaged, just polished. The bolt edge is worn down about 1/32" The PO must have done this years ago and it seems to run fine. Anything I should check or look for to determine if there is any damage? I am not too confortable with major engine work. Obviously I will change the bolts.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It depends on how worn the pushrods are. If they're just polished a bit replace the long bolts and don't worry about it. If there's a noticeable amount of metal gone you can get replacements, usually through your FLAPS.
| | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Rebuilt my 61-261 and found the same situation with long coil bolts. Some of the pushrod was whittled away, but new pushrods were part of the program. I imagine there are a lot of engines with this defect. I learned to use the old bolts or investigate the length of replacement bolts for proper depth fitment. A lot of the newer bolts are in 1/4 inch increments and may bottom out in blind holes or protrude to far in thru holes. Aaaarrrrrgggggg somethin else to remember!!! | | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | Thanks for your input. I will inspect them again but maybe they are ok. Of course the bolts had to line up with both pushrods. 1/4 " over would have made all the difference! | | |
