| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 52 | Does anyone recognize this lever and familiar with to know of an easy way to determine which gas tank in my '60 Burb it's pulling gas from? It is currently pointing toward front of Burb. The two tanks are over and under. Probably common sense, but the Burb is new to me and with the nearest station 21 miles away, and gas as expensive as it is, I'd feel better knowing and only having to top off one at the station. Plus, the fuel gauge doesn't work! With lever now facing front, would it normally pull gas from the main original tank? Appreciate any Stovebolters input. http://i1279.photobucket.com/albums/y525/Azburb/a950da530456a6d5002c87e8496ea197_zpsd56c05f8.jpg | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is no way to determine how the installer plumbed the valve by looking at the handle. You need to look at the pipes and determine where they lead. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | ... and with the nearest station 21 miles away, and gas as expensive as it is, I'd feel better knowing and only having to top off one at the station.... ???? You are going to use the same amount of gas whichever tank(s) you are using.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | drive it till you run out of gas, dump your 5 gal can of gas into one tank, if it doesn't start, turn the handle the other way, question answered  Bill | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | drive it till you run out of gas, dump your 5 gal can of gas into one tank, if it doesn't start, turn the handle the other way, question answered  Bill x2, then mark which is which with a permanent Sharpie... | | | | | Joined: Jun 2013 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 52 | Hey Bill, I was waiting for that one! Ha that's probably the solution though. My neighbor up at the cabin (a 35 year full time chevy mechanic) who's been doing all the mechanical for me, said it's somewhat of a mystery to him. Last week he installed all new gas lines, and said he had not seen tanks like that on any of the old cars he's worked on. They are not rectangular tanks, but are each more a rounded "L" shape and fit into each other perfectly. Then, the original owner had a full skid plate under both that is welded as part of the trailer hitch. Pretty rugged setup, but put together well for those hunting trips. With the low gear ratios, I can't imagine how long it took him to drive the Burb to Alaska. Haven't had it on the highway yet, but think It'll be lucky to hit 60. I'll know in a couple of weeks! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If someone installed new fuel lines he should know which one he hooked to what port. The pointer points to which port is open. | | | | | Joined: Jun 2013 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 52 | Master Gabster, what am I missing here? Boy I wish I had taken auto mechanics instead of mechanical drawing in school! Seems logical, and thanks for the reply, but the old rusted pointer, per pic, just doesn't show any particular ports from above, so even looking at it from underneath, or taking it apart, without knowing which inlets correspond to the pointer, we're just going to have to do a 50/50 trial and error? I'll know soon, probably on mile 17! I'm learning slowly, but will know this Burb inside out before it's over. http://i1279.photobucket.com/albums/y525/Azburb/a950da530456a6d5002c87e8496ea197_zpsd56c05f8.jpg | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You can't see the valve while lying under the truck? | | | | | Joined: Jun 2013 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 52 | I'm heading back up to the cabin on Friday and will snap some pics from under the truck and see if it will lead to an answer. Thx. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | This isn't rocket science.
Fill both tanks. Leave the handle pointed in one direction. Drive it for a week. The tank with the missing gas is the one the handle is pointed at.
I had this set up on my '73. When you fill up you need to switch tanks. Otherwise the gas in the un-used tank will get stale after a while.
| | | | | Joined: Jun 2013 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 52 | Appreciate the replys. My neighbor who installed the lines is out of town, so no feedback on why couldn't trace fuel line to correct input. He's no novice though, so must be a reason. I was hoping to eliminate having to buy $100 + in gas to find out, but think that'll be the easiest solution. Once I get the floorboard, etc all cleaned up, I'll get new markings on for sure. Will also remember Johntsmith's advice on changing over tanks each refill! Good advice and appreciate it.
