| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | I am in the process of putting my truck back together. I hooked up the battery and smelled wires burning. The black wire from the starter goes to the amp meter, comes out the other side of meter BLK/WHT and goes through firewall. I added a voltage regulator relocation kit because I have a alternator that has internal. Any ideas what caused it? thanks | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Look for past posts dealing with this. A quick way to find problem is with a trouble light (ice pick looking thing with a light bulb in the handle). If no current draw then the test lamp will not light. Put it between a disconnected battery cable and it's post. Start pulling fuses until the light goes out. You found the bad circuit. I would first look at any new circuits. Lift wire off terminals if no fuse in that circuit. Good luck
