| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 40 | Hi, Could anyone help ID this front wheel cylinder part # .....1074903......1 1/4 bore Thanks Guys !!!!!!![i][/i] | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Chevybruce, is that number a casting number or a part number? If you could tell us what the wheel cylinder fits we might be able to assist you, what year, size of truck, and front or rear wheel cylinder? | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Search engines are your friends. http://gmpartswiki.com/gmpart?gmpartno=1074903Click on the books to open, shows 51-52 3/4 T, front
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Chevybruce, back from the car show and time to do some research, 1074903 is for a 1938 - 50 4100-6800. Raybestos p/n is WC3406 $24.88 Can. at RockAuto, hope that helps. | | | | | Joined: Apr 2009 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 40 | Thanks to Everyone for your help ,,,,PROBLEM SOLVED !!!!!!! | | |
