7 members (Goach2, Donf, Rusted Nut, Bill Hanlon, JW51, BC59, 1 invisible),
61
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95196 03/23/2006 10:39 PM | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | I am planning to wire turn signals into my 52 using dual filament sockets and am curious about how to go about this. The tech article is for single filament lights. How do I go about wiring a dual filament? I may answer my own question here but can you splice the original brake/parking wires into one wire on the dual filament socket and then run new wires (identical to the tech article for a signal-stat 900) for the turn signals and splice them into the second wire on the socket? The bright filament of the bulb should be the flasher. Want to know what I am getting into before I start. | | |
#95197 03/23/2006 11:01 PM | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Hello,You can purchase dual filament contacts and springs that will fit into your sockets at any auto parts store.You might have to modify the insulated washer by grinding it down a bit to fit your socket. You can then wire the turn signals and running lights separately.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#95198 03/23/2006 11:16 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The rear are already dual contacts. You will need to run another wire back & put one wire to each brake light. It,s a good idea to get some 3 or 4 strand trailer wire & replace all the wires going back. The front you can do like GTO posts get universal sockets & put them in your presant lights. Follow the diagram with the 900. It is a very good unit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95199 03/29/2006 7:36 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Replacing the single contact base in the existing socket is cheap using the napa dual contact bases, i think I paid $1.50 each. After that its just wiring.
Take the old round single contact disc with you to napa, tell them you need one of the same size with two contacts and yer done. Then get a set of dual contact bulbs.
#95200 03/30/2006 3:56 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | see:: this little wire kit allows you to run a single filament bulb working as two bulbs. SO you can have a turn signal and brake light and they are the SAME BULB Make #JE-SFL work like a double filament light with our wiring conversion! One per light needed. #L-JE01 Conversion for JE-SFL (each) $5.00 http://www.watsons-streetworks.com/other_lights.html
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#95201 03/31/2006 3:22 PM | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | Thanks! I appreciate all the replys. Kinda figured this was a change the filament and do some additional wiring type of job. Hopefully I can get this done over the weekend. Question though... when I wire the turning signals to the rear they can be totally independent of the brakes right? In other words I do not need to wire through the brake switch like what is shown in the tech tips. | | |
#95202 03/31/2006 3:36 PM | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | Answered my own question by the amazing power of not being an idiot! Forgot that the tail light is already dual filament with tail light and brake light functions... This needs to be wired just like the tech article. Wow! Hope I redeemed myself on that one by catching it before anyone else read it! | | |
#95203 04/03/2006 10:54 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | ok. the turn signal switch flashes the brake light filiment in the rear. that is the heavyer looking one. the switch disconects the brake switch from the side it is flashing, you need one wire from the brake switch to the turn signal switch and two wires to the rear brake light eliment. an other wire feeds the tail lights, the smaller filiment. another two wires from the turn switch go to the front lights. add a power wire to and frome the "flasher" it is a hand full of wires for so simple a job.
"It ain't a truck if you can't hose out the cab."
#95204 04/11/2006 4:25 PM | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | Thanks for the replies. Got her all wired up and operational. | | |
