6 members (Gdads51, J Lucas, Shade Baby, Lightholder's Dad, Otto Skorzeny, rfs56trk), 71 guests, and 1 robot.
Topics128,038
Posts1,055,585
#95185 03/22/2006 2:33 PM
Junior Member
Junior Member
Hello All. I have a problem that I hope someone can help me with. I have a 66 Chevy Fleetside P/U and have no power to my brake or tail lights. But the turn signals and the headlights work great! To make a long story short, they were working prior to me fumbling under the dash trying to disconnect an aftermarket temp gauge! Being that I am Electrically Challenged, what do I do?
DINO
#95186 03/22/2006 3:23 PM
6 heaven
6 heaven
do the rear turn signals blink on both sides,
#95187 03/22/2006 3:26 PM
Junior Member
Junior Member
Thanks for Replying. And yes, both turn signals blink
DINO
#95188 03/22/2006 3:31 PM
Remove the tail lights, clean the bulb socket and the bucket, apply some dielectric grease to the socket and reassemble. The tail lights are notorious for losing ground, but this is remedied with a good cleaning.
Follow up by checking the two wires that attach to the brake light switch located at the top of the brake pedal. The brake light switch can be adjusted to work properly as the brake pedal is pressed. Sometimes the wiring is kinked or pulled from the blade connectors on the brake switch while working under the dash.
Good luck with your brake light repairs. I hope this helps.
#95189 03/22/2006 3:36 PM
Junior Member
Junior Member
Thank You much for your Advice. I will check the wiring and let you know the results
DINO
#95190 03/22/2006 11:39 PM
Riding in the Passing Lane
Good sugestions. Also check the connector where the wires to the rear lights go through the firewall.
1972 Chevy c10 Cheyenne Super
