9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop),
105
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95185 03/22/2006 2:33 PM | Joined: Mar 2006 Posts: 8 Junior Member | | Junior Member Joined: Mar 2006 Posts: 8 | Hello All. I have a problem that I hope someone can help me with. I have a 66 Chevy Fleetside P/U and have no power to my brake or tail lights. But the turn signals and the headlights work great! To make a long story short, they were working prior to me fumbling under the dash trying to disconnect an aftermarket temp gauge! Being that I am Electrically Challenged, what do I do?
DINO
#95186 03/22/2006 3:23 PM | Joined: Aug 2005 Posts: 124 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 124 | do the rear turn signals blink on both sides, | | |
#95187 03/22/2006 3:26 PM | Joined: Mar 2006 Posts: 8 Junior Member | | Junior Member Joined: Mar 2006 Posts: 8 | Thanks for Replying. And yes, both turn signals blink
DINO
#95188 03/22/2006 3:31 PM | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Remove the tail lights, clean the bulb socket and the bucket, apply some dielectric grease to the socket and reassemble. The tail lights are notorious for losing ground, but this is remedied with a good cleaning.
Follow up by checking the two wires that attach to the brake light switch located at the top of the brake pedal. The brake light switch can be adjusted to work properly as the brake pedal is pressed. Sometimes the wiring is kinked or pulled from the blade connectors on the brake switch while working under the dash.
Good luck with your brake light repairs. I hope this helps. | | |
#95189 03/22/2006 3:36 PM | Joined: Mar 2006 Posts: 8 Junior Member | | Junior Member Joined: Mar 2006 Posts: 8 | Thank You much for your Advice. I will check the wiring and let you know the results
DINO
#95190 03/22/2006 11:39 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Good sugestions. Also check the connector where the wires to the rear lights go through the firewall. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
