4 members (55shaker, Cosmo, Gdads51, 1 invisible), 118 guests, and 2 robots.
Topics128,069
Posts1,055,896
Members48,428
Does anyone have a chart showing what candlepower various light bulbs have? Example 1157 vs. 2057.
I used to have a chart showing almost every bulb size available, but I lost it.
Kael
The 1157 and the 2057 are almost the same lamp the different is the base.
Kael,
If you are willing to cross reference the information on these two links, I think you will find what you are looking for: in 6v and 12v; and, in CP and watts.
Bulb numbers and applications for mid 50s 6v & 12v bulbs. Use the MFG. NO. from this link and look for specs in the next link.
Cross-reference part numbers with information on wattage and CP.
Good luck,
Tim
