3 members (Phak1, Otto Skorzeny, TexasA&M48Truck), 110 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
I have a 66 c-30 with a 327, currently semi defunct. The passenger side exhaust manifold was leaking at the exhaust pipe, i went to tighten the bolts and broke the corners of the flange on 2 bolts. I could take it off and weld the pieces back on, but since its a work in progress i figure that if the old one has to come off, if new ones arnt stupid expensive; new ones should go back on! Long story short- this is a project i bought in horrid condition, now its just in bad condition. Its a daily driver sort of rat rodish, i dont need super high end manifolds, wouldnt mind just replacing the ram horns with new ones, im just looking for ideas with the same style manifolds. It is square port, and the pipes are already done. Im looking for "bolt on" replacements. Any input would be greatly appreciated!
66' Chevy C-30 Rat
Riding in the Passing Lane
There should be plenty of used ones avail. Put an ad in the parts wanted. Look in Craigslist & E-bay. If there are salvage lots in your area that have some older stuff check that or a local swap meet.
1972 Chevy c10 Cheyenne Super
Dorman makes a good replacement rams horn manifold. Prices are reasonable. Most of the aftermarket suppliers are ridiculous.
Still lots of them available at swap meets.
Fred
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I got a junk yard one to get me by for a minute, but ill be getting new ones here shortly. Thank you guys for your help!
66' Chevy C-30 Rat
