| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 217 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 217 | I just picked up a front axle that is a 49 to 54 1/2 ton is their any way to tell what year it is, or do I need to worry about it. are they all the same ? I want to put new king pins and brakes on it so will I need to know the year? thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1941-1955st 1/2 ton front axle bars are the same
brake parts and steering knuckles differ between 49 and 55st
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The only difference between 1941-50 spindles and 1951-55 first series spindles are the size of the two bottom holes used to mount the backing plate and steering arm. 1941-50 have 7/16" holes on all four holes. 1951-55 1st have 7/16" on the two top holes and 1/2" on the bottom two holes.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2013 Posts: 217 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 217 | thanks, I want to put this under a 31 chevy pickup so I will have hyd brakes. looks like a near bolt in change Jay D | | |
