3 members (Gray_Ghost, Jims46, Hotrod Lincoln), 254 guests, and 1 robot.
Topics128,088
Posts1,056,113
Members48,434
1. any suggestions as to where I should get an ignition switch for a 41 1/2 ton? the hole in the dash measures 1 inch.
2. my headlight switch has 5 posts but none are labeled. does it matter how/where I attach things to it? (yes I know, this is a stupid question). thanks, joe
1. This might work.
Or, you might want to post a Part Wanted ad in the Swap Meet.
2. A schematic diagram diagram of the light switch is in this wiring diagram. The orientation of the posts should match the diagram. The names of lines are not clear, but trace the line to the device (that name might be clearer).
More helpful/knowledgeable members will post better information.
