1 members (joe apple),
110
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | 1. any suggestions as to where I should get an ignition switch for a 41 1/2 ton? the hole in the dash measures 1 inch. 2. my headlight switch has 5 posts but none are labeled. does it matter how/where I attach things to it? (yes I know, this is a stupid question). thanks, joe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1. This might work. Or, you might want to post a Part Wanted ad in the Swap Meet. 2. A schematic diagram diagram of the light switch is in this wiring diagram. The orientation of the posts should match the diagram. The names of lines are not clear, but trace the line to the device (that name might be clearer). More helpful/knowledgeable members will post better information. | | |
