0 members (),
134
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 41 | 65 truck with 350. Does anyone know of a good kit to fit this? Stock radiator. Truck runs cool but will heat up slowly with any amount of idling. Truck has shroud and flex fan. Fan is in shroud opening,but not in too far. Any help/info greatly appreciated.Thanks
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Put a regular fan on and throw the flex fan away. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | You could add a fan clutch with regular blades. This would give you more power saving then the flex fan and at the same time move the fan blades closer to the back of the radiator for better cooling.
