Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 134 guests, and 6 robots.
Topics128,281
Posts1,058,471
Members48,490
65 truck with 350. Does anyone know of a good kit to fit this? Stock radiator. Truck runs cool but will heat up slowly with any amount of idling. Truck has shroud and flex fan. Fan is in shroud opening,but not in too far. Any help/info greatly appreciated.Thanks
Put a regular fan on and throw the flex fan away.
You could add a fan clutch with regular blades. This would give you more power saving then the flex fan and at the same time move the fan blades closer to the back of the radiator for better cooling.
