| | | Forums66 Topics128,084 Posts1,056,083 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 3 New Guy | | New Guy Joined: Apr 2013 Posts: 3 | I've got a 53 3100 with a 235 4 spd and closed drive line. Just developed a growling vibration when decelerating but will go away when clutch is pushed in . Only really notice it at higher speeds. I'm leaning towards it being something in rear end. Any help would be much appreciated. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | First thing to check is tranny and differential fluid levels before you do much more driving.
Ed
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Sounds like diff problems... | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Noise on deceleration is uncommon with a rear end. I suspect the U' joint may be coming loose.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2013 Posts: 3 New Guy | | New Guy Joined: Apr 2013 Posts: 3 | Checked fluid levels and trans was a bottle and a half low . Diff was a little low but not much. Also found the cap and gasket that screws on to champaign glass section of tube that goes around ujoint was just hanging on the tube. Tightned everything and filled fluids went for short test run and everything was quiet.
