9 members (cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible),
109
Mod | | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Bench breaking in a 61-261 and noticed something like a lite brown mollases stain down the side of the block in about 3 places on the exhaust (hottest) side of the engine block. The biggest concentration of "stain" seems to be coming from the head gasket area between #3 intake and #4 exhaust. Its not an oil leak 'cuz the stain cannot be removed even with solvent, as if its baked on. Compression checks at 163 to 169# with nothing strange noted, spark plugs look good, head bolts torqued to specs, vacuum holds good and steady @20 inches, valve cover gasket does not leak, engine runs smooth in all rpms, no oil in the coolant and no coolant in the oil. Looking really close at the "active area", you can see minute bubbles developing then a minute clear drip of something going down the side of the block. Had the head magged during teardown and no cracks. found. Could it be the head gasket filler material breaking down in all the heat. Don't know if this symptom is a precusor to something more terrible to come, or not to worry. Thanks for your insight
to between #3 intake and #4 exhaust ports. | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Did you use any type of sealant material on the gasket? | | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | No dope, head put on clean and dry | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Have you retorqued the head yet? It would be a good idea.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Retorqued bolts, all were to spec, no retightening | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Did you back each one off one at a time and then retorque? Just checking the torque from where they are is no good. The bolt has to be moving as it reaches it's torque setting. Because of friction it takes more to start a bolt moving that to keep it moving. The bolt needs to be moving when it reaches it's correct torque.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Getting late in this part of the country, will do that tomorrow. I assume that each bolt is loosened and retorqued, as opposed to loosening them all and restarting from the beginning. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Yes, one at a time following the torque chart sequence.
