2 members (cmayna, Wickedbass), 71 guests, and 5 robots.
Topics128,086
Posts1,056,101
Members48,434
#950016 06/12/2013 10:46 PM
I've got a 53 3100 with a 235 4 spd and closed drive line. Just developed a growling vibration when decelerating but will go away when clutch is pushed in . Only really notice it at higher speeds. I'm leaning towards it being something in rear end. Any help would be much appreciated.
First thing to check is tranny and differential fluid levels before you do much more driving.
Ed
Sounds like diff problems...
My 46 GMC on Photobucket
Yup ^^^
Noise on deceleration is uncommon with a rear end.
I suspect the U' joint may be coming loose.
My Blog
Checked fluid levels and trans was a bottle and a half low . Diff was a little low but not much. Also found the cap and gasket that screws on to champaign glass section of tube that goes around ujoint was just hanging on the tube. Tightned everything and filled fluids went for short test run and everything was quiet.
