8 members (Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren), 83 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#94985 03/09/2006 11:57 AM
Junior Member
Junior Member
I have a 66 C20, I am trying to get my lights to work, not a new topic, and am not familiar with Chevy wiring habits. How are the exterior lighting systems grounded? Do they have separate ground straps for these systems, or do they ground through their respective cases? If there are straps, where should they be? Thanks, Josh
#94986 03/09/2006 12:35 PM
grounded thru lite frame to body body to frame maybe straps in engine bay,,some models used groung cable with a small wire that grounded to body in engine bay,,most times it,s in the socket and bulb...doc
#94987 03/10/2006 1:25 AM
Check the dimmer switch, sometimes they can cause the headlights not to work.
1951 3100 Chevrolet
#94988 03/10/2006 4:05 PM
Junior Member
Junior Member
On my 65, the front light harness has a ground for each headlight. Also shows this on the wiring diagram. Dont know if this helps.
Patrick
