8 members (32Fordpuchoptop, FAST55, Otto Skorzeny, mason86, rfs56trk, TexasJim50, Forty9, DadsFirstPickup),
133
Mod | | | Forums66 Topics128,049 Posts1,055,658 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94972 03/07/2006 11:39 PM | Joined: Jan 2006 Posts: 33 Junior Member | | Junior Member Joined: Jan 2006 Posts: 33 | Hello, I have a 66 C20, 250 I6 MT. I have gotten all my exterior lights to work except my front turn/park lights. The rear park/stop lights and turn signals work, just not the front. The headlights also work. Could it be in the switch? Does anybody have a good wiring diagram for this year and system? Maybe also a dashboard diagram? Thanks, Josh | | |
#94973 03/08/2006 1:27 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | make sure you have a good ground.the parking lights work only when the headlights are off. | | |
#94974 03/08/2006 2:19 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | also check no wires fell off the switch - front park lites get power same place/time as the tail lites
Bill | | |
#94975 03/08/2006 4:05 AM | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Ijust went through the same thing with my 66 c-3o.Front signals quit working.Putzing around lowered the hood some and worked fine.Raised the hood and looked again and no lights..Closed the hood and work fine again.Havent fixed it yet but i asume ive got a bare wire.The way i noticed the problem was when i turne the left or right signal on ,both would blink on the dash but not externaly.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | |
#94976 03/08/2006 5:15 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Ground. Ground. Ground. Seems like this is asked every week. When some bulb other than the proper one is flashing that means the current is flowing across the turn signal filament, back across the park light (or tail light) filament trying to find a place to ground itself. In Slow..Rider's case it was finding it at the instrument panel. In other cases it travels the park light wire to the other side, goes through the other parklight filament and finds a ground there.
You guys with turn signals in the hood might consider a ground strap from hood to cab. I don't know but I'm guessing they're supposed to ground through the hinges but don't do it after 40 years. That would explain Slow..Rider's working with the hood closed but not open. It's finding a ground at the latch. | | |
