1 members (Shade Baby),
152
8
Mod | | | Forums66 Topics128,106 Posts1,056,214 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Replacing the side cover gasket on my '50 216. Think that I'll glue the gasket to the cover and glue the cork gaskets for the spark plug holes to the cover also. Anyone have any advise???? Thanks Don | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | You will probably get lots of advice. Everyone has there way of doing it. I don't use any glue or sealants. If the metal is straight and flat the cork gaskets will seal just fine. And the next time the cover comes off no mess to clean up. My opinion only. Cleon | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I used a tack spray on those gaskets. Holds well and cleans up with thinner.
Drew
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | You can keep the gasket in place by tying it to the side panel with sewing thread. Once the bolts are started, remove the thread.
1939 Chevrolet Stake Truck
| | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | When I ripped into my own 216 the old gasket was tied with small thread like rickmg describes. I would guess they were done that way from the factory. The thread was still in place. I have pictures but have never really mastered posting them... Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I glue them to the panel & put a layer of RTV on the lower part. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | What wrenchbender says. Hopefully you won't have to take them off soon but I have found that cementing them to the cover the cover will come off with the gasket in tack and can be reused....most of the time anyway. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I guarantee you the factory did not tie the gaskets with thread. Cleon | | | | | Joined: Jun 2013 Posts: 6 New Guy | | New Guy Joined: Jun 2013 Posts: 6 | When I did the side gasket on the 216 I used the cork gasket along with RTV like mentioned above. Infact, I did the same thing on the 261 I have currently in my truck, and haven't had any problems. Jeff | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I glue the gasket to the side cover with RTV, so when the time comes, the gasket is easy to remove from the cover. On the engine side of the gasket, I smear a light coat of grease, so the gasket won't stick to the block when I remove the cover from the block.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I have nothing against learning new old working methods from more experienced mechanics. That is why I was fascinated when I found my old valve cover gasket tied in place with thread though all the upper screw holes and several of the others too. This was on a 216 from 1941. Maybe this was not done from the factory - I wasn't there. But in that case it was done in the late 40's or 50's. The car has been in the family since new and I believe we would have known about any valve work done later. It isn't really important, but it would work to keep the gasket in place during assembly without gluing it. How long has gasket sealer been an essential part of engine work? These days I would choose the glue, too. I'm not getting the link to work in any polished way, so check out : http://www.nelsonorgel.se/bild/truck/cover1.JPG
It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I used a tack spray on those gaskets. Holds well and cleans up with thinner. This method worked well for me. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i just cut the heads off 4 2in. bolts and screwed them into the holes and slid the gasket, then the cover on and replaced them one at a time with the bolts
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The last method by hoozat has the added advantage of locating and holding the metal in place too. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | That's the way I located and attached the push rod cover and gasket on my '54 235.
Check the bolt holes to make sure that old RTV or silicone has not built up inside to prevent the cover bolts from fully seating. Do a test run before adding sealant to make sure that there is space to hang the cover over the headless bolts and that you can get to them easily.
I used Permatex Super 300 on both sides as Jerry "Hotrod Lincoln" suggested to me.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Just installed new gaskets on my old 235 high torque, tall side cover also like the 216. Glued the gasket to the cover first using Permatex #2, held in place with a bunch of clothes pins until dry. Then more #2 to side of motor, no leaks. | | |
