5 members (1955 1 Series, Southerntruck, tclederman, Rusted Nut, Peggy M), 38 guests, and 8 robots.
Topics128,010
Posts1,055,308
Members48,419
#949647 06/11/2013 4:13 PM
do I need to swap out the 6v Flasher for a 12V one?
I like the flasher that is 6v has nice connectors and a bracket built in it. Probably will need a 12V one
That flasher will most likely flash fast. If that is not an issue then use it until it quits. Should be able to put a 12 volt back in the same location. The mounts did not change. The pin out is the same. Might be a bit taller or shorter over all and that should be no problem. The flasher works with current and heat. More current is more heat. When the "bimetal" contact gets warm it moves away from the power contact and then cools off and moves back in to the power contact. Simple as a house thermostat. ....in the old days any way. smile
Steve H
