0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | have a 48 gmc 1/2 ton with a 228 motor and 1 barrel carb, Rochester...had a 5/8 spacer between the carb and manifold, it broke in pieces, do I need the spacer? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, it's not a 'spacer' it's an insulator to prevent boiling the gas in the float bowl
Bill | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | You may want to talk with other stovebolters in your area to see if they are running this insulator. Climate in your area may not require it. If it does they are available from the usual vendors, if not just a gasket will do.
Ed
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | In your area, so north, I would use it. In the summer it helps keep the carb gas from percolating. In the winter, as long as your manifold heat flapper works, it will help prevent carb frost from a vacuum leak on the manifold. They are made of bakelite(a resin) now, not dense paper fiber.
Drew
| | | | | Joined: Jan 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 34 | have a 48 gmc 1/2 ton with a 228 motor and 1 barrel carb, Rochester...had a 5/8 spacer between the carb and manifold, it broke in pieces, do I need the spacer? It was put there for a reason | | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | where can I get one, or can I make one, if so what material can I use to make one. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | right here. http://www.oldchevytrucks.com/cart/index.asp?cat2=10336&path=1947+%2D+Early+1955+Truck+Parts%2FMechanical%2FFuel+System%2FMiscellaneous+Carburetor+Items | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i just posted the page so he knows where to get one. which one it is exactly i dont know. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Reproduction spacers/insulators are made from injection molded plastic and not bakelite as was original. For several years I worked with this material making piston rings for gas compressors which will swell ever so slightly assisting sealing ability. This is why gaskets are usually required that were not there in the first place. Throttle rod length will probably also be an issue leaving it out.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | A gasket was not specified on either side of the insulator - it was directly against the intake manifold and the carb. I tried gaskets on both sides of my reproduction plastic insulator, but it raised the carb too high and as a result the throttle rod was too short. I finally bought an original Bakelite insulator from another Stovebolter. It seals tightly and doesn't require gaskets. QUESTION: What is the difference between the early and late insulators that Tim showed? Is it the location of the vent for the power piston? Or do I just have a screwy carb that someone built from various parts? The vent on my Rochester B carb ('54 235) is close to the mounting holes. The gasket that came with my NAPA carb rebuild kit has cut outs for the vent in the same location as my carb. But the reproduction plastic insulators that I bought - both early and late - have the cut out farther away from the mounting holes. The plastic insulator covers the vent. The Bakelite insulator that I bought from George also had the cut out as on the reproductions. I cut out a new vent on the Bakelite insulator. If I had cut out a new vent at the indented mold mark on the plastic insulator, I bet that the carb would have leaked near the edge - see first pic below. > Vent locations: Left=Rebuild gasket; Right=Aftermarket insulator> Power piston vent - similar to my carbThanks, - Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | the stud spacing on the manifold is different. | | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | got lucky guys, my wife work in a place that makes cathaders, and deal with a lot of that kind of plastic, so they gave me a chunk and I made one, thanks for the help everybody... | | |
