7 members (Wayne67vert, baldeagle, 74cheyennesuper, NorCal52Suburban, Ponchogl, Peggy M, NJC), 60 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#949131 06/09/2013 1:00 PM
i have an issue with my wiring i hope some1 here could help me figure out. Ok my turn signal's front an back all work correct however when i turn my truck headlights on my tail lights don't come on with them then when the battery is hooked up the taillights stay on steady but when i push the brake pedal to stop they go out instead of getting bright the truck is 77 chevy pickup wiring harness auto tran's please post if you can help me solve the prob thanks much
1957 Chevy Service Station Wrecker
3B Offline
Hy toychaser2005, your question is a little confusing, in the middle of your description, you talk about hooking up the battery, the battery would have to be hooked up for anything electrical to work. It sounds like you might have two different problems. "A" your tail lights go out when you step on the brakes, that is usually caused by insufficient ground at the tail light mountings, if your housings are metal, then make sure where they are bolted to the truck is nice clean shiny metal, if they housings are plastic, add a ground wire to each one. "B" Your tailights don't come on with your headlights, that could be a faulty switch, incorrect wiring of the switch, or damaged wiring/disconnected plug somewhere between the switch and the tail lights, hope that helps.
ok thanks much ill see if i can figure it out
