| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 54 | Can any one tell me how the oil flows thru the canister. I took mine apart today because no oil is coming out of the return line. After cleaning it i can't find any obvious return ports in the main tube that the return line screws into. It appears that once the canister cover is put back on, there is no way for the oil to get to the return line. The return line actually came off while the engine was running and no oil was flowing out of it. Any thoughts? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A photo of your filter would be helpful. What year engine? What brand of filter unit?
Typically, oil flows into to filter from a line near the rear of the block into a fitting high on the rear side of the filter unit. The oil goes into the canister on the outside the filter cartridge.
The oil then moves through the filter cartridge to the center of the filter cartridge and into/out a hole near the top of the hollow center post.
The oil exits the bottom of the unit through the bottom of the hollow center post.
| | | | | Joined: Apr 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 54 | Thanks.
I saw what i thought was a dimple in the main tube. I tried sticking a awl into it but it didn' free anything. After your response I was able to stick a thiner wire into it and it broke thru. The is a little less than a 1/8" in dia | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Clean it out and blow it out and clean it out again. See if you can get flow.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Remember this is not full flow. Your filter is only filtering a small sample of the oil flowing through your engine. Not like todays cars. Its a good idea to clean that out and have it functioning as intended. Its not the best, but its necessary. | | |
