1 members (klhansen),
103
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Do you really have to pull the front cover (and everything associated with it) to get the front engine mount bolts in and out on an Advance Design truck engine mount flange? I have torqued them around every which way and even swore at them to no avail.
Bruce | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I ground the side off of one of the carriage bolts on the front motor mounts. The fine thread bolt was originally permany attached. Mine were missing so I replaced with carriage bolts. Here is my post about the process and list of fasteners: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=825049#Post825049NOTE: I placed the two thick washers in the wrong place. They should be against the top surface of the crossmember. There was a recent thread on the subject. Maybe someone will link to it. I'm typing this in my iPhone, so it's a little hard to search and link. EDIT - Here is the link to the thread about the correct location of the two outside thick washers: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=923761#Post923761- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | |
