1 members (baldeagle),
87
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94875 02/28/2006 3:03 AM | Joined: Nov 2005 Posts: 16 Junior Member | | Junior Member Joined: Nov 2005 Posts: 16 | Can anyone tell me how many ground straps I am suppose to have on a 65 with V8? I thought 3... engine to cab, cab to frame, bed to frame. Am I missing anything? Saw that the 67 and newer have 5 total??? | | |
#94876 02/28/2006 5:31 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I would go Battery-Negative to engine block ... Battery-Negative to frame ... engine block or frame to firewall.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#94877 02/28/2006 3:36 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | if you're running an electric fan @ the radiator, that would be another - radiator support frame to chassis frame.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#94878 02/28/2006 11:29 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A lot of mid 60,s had extra ground straps from the engine to the firewall. It was mostly for radio suppression. Some of the early 70,s had one under the air cleaner wingnut. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#94879 03/01/2006 12:37 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | It also provides an easy way to ground anything you add under the dash.
When I installed my AC/Heat unit, I needed to ground the blower motor and all I had to do was run a 5-inch ground wire to the firewall. Nice and easy.
