| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | Several months ago I disassemble my 235 from our 55.2 3600 chevy truck. I had labeled everthing since I knew it would be awhile till it was re-assembled. When I was putting the rocker arm rack assembly back on, I noticed I had a small piece of thick wire saved in a baggie tied to the rocker assy. I have no idea what this is for or where it goes. I am not able to take any pics and post them, sorry. Does anyone know what I am talking about, or maybe it doesn't even go with the motor? Thanks. Brian
1952 GMC model 473 dump truck 1951 Chevy 1500 stepside
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Brian, Is your truck's engine a 1955-2nd series engine? If it is, here is an illustration of the right half of the rocker arm assembly. The parts to the left of the oil connector are basically similar to the parts shown in the illustration. Do you have the clip a each end? If you are missing one or both clips, maybe that thick wire is a cob-job substitution? | | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | TC, I do have the clips on both ends of the valve train rocker shaft. This piece is bent into a U- like shape? Maybe 3/4 of an inch in length. THe wire is about the diameter of a coat hanger. Hopin it is nothing I need, gonna fire it up on the engine start stand this week anyway. My buddy says he will help me post a pic of it on here. Thanks for your insight. Brian
