2 members (WarEagle1, 1 invisible),
172
Mod | | | Forums66 Topics128,284 Posts1,058,522 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94831 02/27/2006 8:59 AM | Joined: Oct 2006 Posts: 4 Junior Member | | Junior Member Joined: Oct 2006 Posts: 4 | I have a problem with the Rt. blinker mode on '66 Chev shorty.... When the right signal is on and flashing, the left is too. Left signal does not affect right and both fronts operate normally. Ck'd w/ VOM at rear bumper area plug,,,, Problem is ahead of that.. right now have no st wheel puller, but suspect elect contact bridging under st wheel.... any other ideas? Also will a stock 350 temp sender operate the dash gauge correctly on this pu? orig. engine was a 283 I believe...'Thanks!
Never give up!
#94832 02/27/2006 9:48 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I'm thinking like you ... contact is hitting under the steering wheel -- or in the blinker switch assembly ... or it could be grounding somewhere/anywhere between there and the right blinker.
Since the left flashes when the right is on, the wire from the right must be connecting to the left somewhere.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#94833 02/27/2006 12:08 PM | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | It's a BAD GROUND on the right side tail light, so power is having to travel throught the tail light on the right side, then to the tail light on the left to find ground.
Turn on the tail lights, then step on the brake, does the right side go out, and the left side works? If so then its the Ground. If both side light up with the tail lights on and stop lights, then yes it could be a bad switch. If the wires were shorted out some place then if would do the same both ways. | | |
#94834 02/27/2006 5:46 PM | Joined: Oct 2006 Posts: 4 Junior Member | | Junior Member Joined: Oct 2006 Posts: 4 | grounded tail light inner assy to bumper - no change. brake lts do work with taillights on. i'm still thinking signal plate under wheel because the innards look bright under there like someone replaced it, but the wires on the st post look original - maybe a bad solder job.... thanks for the input!
Never give up!
#94835 02/27/2006 9:04 PM | Joined: May 2005 Posts: 70 Shop Shark | | Shop Shark Joined: May 2005 Posts: 70 | Donny.
Try running a tempory wire from the battery negative terminal to the frame of the right tail light to eliminate any chance of a bad ground. Easy to try and it will eliminate a lot of guesswork.
52 Ted
illegitimi non carborundum
#94836 02/27/2006 11:51 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The temp sender was the same 78-79 on back. Make shure it,s not for a warning light. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
