| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | can someone tell me which side of the coil the wire to the distributor bolts to? Is it the + or - side? I bought a 1 1/2 ton stake truck and I'm trying to get it started. Thanks in advance. Dave | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | battery to +, dist to -
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It is best to ID the year and make of the truck you are working on. If it is a '55 and earlier GMC, Bill's info is no good. | | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Thanks for the help. It's a 52 chevy 1 1/2 ton with a 216 six cyl. Another quest. how difficult is it to rebuild a fuel pump with the glass bowl on the top of the pump. Dave
