| | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | I have a 51 Chevy 3100. It has an Ls-1 and a 460 e transmission. Is there a kit for the linkage i can buy or is everything hand built ? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If you want to keep it on the column, you will be making it yourself. Otherwise Hurst, Lokar, many of the hot rod shops sell universal linkage kits for the floor.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | yea forgot it's on the column. Anybody got pic's ? | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I have a 51 3105 panel. I used a column shift aftermarket column.
Used a Kugel Komponents column shifter kit to mate it to a T400. Should be very similar install to your tranny.
I'm guessing Lokar or CPP can help you ,too.
mike
| | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | If you want to do a new column, several of the manufactures sell them with builtin column shifters. Check out Ididit etc.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | If you want to do a new column, several of the manufactures sell them with builtin column shifters. Check out Ididit etc. I have the ididt column with column shifter, i was interested in the linkage part. | | |
