3 members (TUTS 59, UtahYork, Otto Skorzeny), 67 guests, and 0 robots.
Topics128,078
Posts1,055,939
Members48,430
#947692 06/03/2013 12:58 PM
I recently wrote to Patricks to see if they had the Ring&Pinion install kit in stock. They do, but need to know what torque tube bushing I need. I have no clue. This is my 49 half ton with OEM 4 speed trans.
Anyone know ?
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Maybe it has to do with the earlier bushing (through 1950) having a pin that holds it in place and the later (51-54) bushing just being a press fit. Do you see a side pin at the end of your torque-tube? The replacement "Okie" bushings are different, so the diameters are most likely different?
Patrick's is probably being careful about being sure what year torque-tube you have?
Jim Carter
Chevs of the 40s
Classic Parts
The dimensions are shown here: BUSHING, Propeller Shaft Housing (torque tube)
It shows four sizes from 1940-1954? Maybe Pre '68 Dave or someone else will clarify this?
As Tim mentioned you need to verify you have the bushing lock pins.
They are in the top side of the torque tube covered by the U' joint bell.
If it is an original 49 torque tube than it will have the lock pins.
The Okie bushing number Patrick's should send you, if it has the lock pins, would be a M102.
My Blog
Ok...thanks guys. I'll get that verified this week.
Mark
1949 Chevy 1/2-Ton
Lucielle
