3 members (mk72, MT53, UtahYork),
100
Mod | | | Forums66 Topics128,186 Posts1,057,315 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 | hi chaps...here we go again...got engine back in the frame...good commpresion...timing all fixed up
run up for 20 mins but cant see any oil coming out to rockers?
should it need more time? i primed the oil pump with a screw driver and oil still didnt come to the top?
under the side plate i have the copper feed pipe.. i have no special head bolt as think the block is 1956...
before running it i covered rocker assemble in oil so its hard to tell for sure...i
there is a small bolt which blanks off just above the distributor, whith this removed no oil comes out? (the head i removed beofre fitting an 848 had a pipe fitting here?
anything else i can do?
1953..panel truck.I love my truck!...
| | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 | just to note.. engine should have remote filter fitted..but i am using a clear pipe for now...and i can see oil pumping...also when priming with screwdriver in drill...oil is flying out of these conections...( i checked by removing the one closest to rear of engine!)
| | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 | B-) fixed....removed side plate and distbutor...put drill bit in again..removed copper feed pipe...and crank...loads of rubbish and gunk came out and in turn had blocked the pipe....
