| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | my 46 2 ton has a sloppy clutch pedal, side to side. too many years of pushing in the clutch with a bit of side load. can the pedal assembly be rebushed? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | https://www.fillingstation.com/ has the bushings and the shaft if needed Bill | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | My '40 1-1/2 Ton had the same problem. I bought the bushings and made a new bar. Now there is no wobble and the pedals go straight through the toe board without rubbing on the sides. | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | is this the correct one? http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z51115~P9.50~~~~S3SQ00YEYF24623521550H~Z5Z5Z5~Z5Z5Z50000014x | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | Those look like the right ones. | | |
