0 members (), 135 guests, and 1 robot.
Topics128,151
Posts1,057,000
Members48,460
my 46 2 ton has a sloppy clutch pedal, side to side.
too many years of pushing in the clutch with a bit of side load.
can the pedal assembly be rebushed?
https://www.fillingstation.com/ has the bushings and the shaft if needed
My '40 1-1/2 Ton had the same problem. I bought the bushings and made a new bar. Now there is no wobble and the pedals go straight through the toe board without rubbing on the sides.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
is this the correct one?
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z51115~P9.50~~~~S3SQ00YEYF24623521550H~Z5Z5Z5~Z5Z5Z50000014x
Those look like the right ones.
