7 members (Jon G, GMCJammer51, Otto Skorzeny, Greg_H, TUTS 59, 1955 1 Series, Joe H),
162
Mod | | | Forums66 Topics128,078 Posts1,056,044 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 31 New Guy | | New Guy Joined: Jan 2013 Posts: 31 | I can not seem to be able to shift from 3rd to 4th without grinding the gears. Any idea what needs to be fixed? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need a new synchronizer in the trans. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2013 Posts: 31 New Guy | | New Guy Joined: Jan 2013 Posts: 31 | where can I get this part and how is it installed? Thanks for your advice. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | does it do it all the time or just when you speed shift? either way in the mean time if you just double clutch it the grinding will go away. try adding two more seconds to your shift time. thats what i would do. i know if you try to speed shift, the tranny doesnt like that in 3rd and 4th unless you shift without the clutch. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you are trying to nurse it along, a thicker oil in the transmission may help. Some folks like the Lucas oil for this. Also, when the clutch is in, try giving it a little shot on the throttle. | | | | | Joined: Jan 2013 Posts: 31 New Guy | | New Guy Joined: Jan 2013 Posts: 31 | 2nd to 3rd gear works great. 3rd to 4th is anyways hard with more difficulty with higher revs. If I take extra time I can get to to drop in without grinding but would like to fix it if I can. Thanks for your advise. | | | | | Joined: Apr 2011 Posts: 50 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 50 | | | |
