3 members (RoadsScholar, Gdads51, Gray_Ghost), 120 guests, and 4 robots.
Topics128,078
Posts1,056,021
Members48,433
I can not seem to be able to shift from 3rd to 4th without grinding the gears. Any idea what needs to be fixed?
Riding in the Passing Lane
You need a new synchronizer in the trans.
1972 Chevy c10 Cheyenne Super
where can I get this part and how is it installed? Thanks for your advice.
does it do it all the time or just when you speed shift? either way in the mean time if you just double clutch it the grinding will go away. try adding two more seconds to your shift time. thats what i would do. i know if you try to speed shift, the tranny doesnt like that in 3rd and 4th unless you shift without the clutch.
If you are trying to nurse it along, a thicker oil in the transmission may help. Some folks like the Lucas oil for this. Also, when the clutch is in, try giving it a little shot on the throttle.
1951 1 Ton Completed
2nd to 3rd gear works great. 3rd to 4th is anyways hard with more difficulty with higher revs. If I take extra time I can get to to drop in without grinding but would like to fix it if I can. Thanks for your advise.
You should find all you need here.
http://www.novak-adapt.com/knowledge/sm420.htm
For with God nothing shall be impossible. (Luke 1:37)
http://s224.photobucket.com/user/72cj351/library/48-52?sort=2&page=1
Paul
