9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc),
89
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 9 | I have a 41 1/2t pu with a straight axle. The truck is completely done, paint and all. It steers like a truck. I have a mid 70s steering column (tilt), pump and ect. can someone tell me how to do this. I have been told that this can be done. HELP HELP | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what does "steers like a truck" mean? all my trucks steer like a car .... if you're wanting power steering, it'll not be simply bolting something it, you'll need a lot of bits and pieces to adapt things to your specific configuration .... apparently you've modified things from original already .... not likely to find anyone here that can tell you how to fix what you've done with yet more modifications  Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | What is the "etc." ? (ect.) What parts might that be?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | if you have all the brackets and pullys to mount the pump to your motor so every thing lines up . you can use a rear steer power steering box from a 69 nova. you will have to cut the steering shaft that goes to your box . fit a support bearing in the bottom of the steering tube. make a plate to mount the nova box . modify the steering arm and get borgeson steering joints & shaft to conect the steering column to the nova box . then have the hoses made. it is a pain to do | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | A little more information on what mod's you have already made to your truck - ie. what engine you have installed - is the truck totally stock now ?, etc. would be helpful. You might try a search of the Forum - I'm sure I have seen some posts over the years concerning power steering mods to straight axles. I have a mid-seventies tilt column installed in my '40. You can use the same hanger location under the dash ( with a new bracket ). As Leonard said, need to support the bottom of the column, then a matter of routing the shaft with borgeson joints and bearings to connect to whatever box you end up with. Lots of brackets available for small block chevies - not sure about the various sixes. Maybe try " Bills Hotrod Accessories " - they have a multitude of applications. | | | | | Joined: Nov 2005 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 9 | I have a 350 sbc with 350 trany the reason I want ps is so its easier to drive. I have a mid 70s ps box, pump and mounting brackets. I thought someone might have done something like what I want to do.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Have a look at Classic Performance Parts, or No Limits Engineering. They make kits for '47 & up. Might be able to make it work on your setup. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | One of the other things you will have to figure out is the pressure line from the pump to the box. If you want to go JIC or AN fittings, there are companies out there that make adapters. With GM pumps and boxes, you want to make sure it is either standard or metric. Trying to go from one style to another can be a bear. That's where the JIC fittings come in handy. http://www.bunchobikes.com/1952suburban5.htm About 3/4 down on the page you'll see I'm starting to mock up hoses. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you have offset wheels, that can make steering harder, have you overhauled your existing box and linkeage, kingpins, etc?
| | | | | Joined: Nov 2005 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 9 | What do you mean off set wheels? The steering is stock , never touched except for mat. Ron | | |
