| | | Forums66 Topics128,147 Posts1,056,801 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | I followed the tech tips but it does not address the issue of how to remove the door handle lever from the striker. Any suggestions? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Not sure I follow... "how to remove the door handle lever from the striker"
| | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | The actual striker is attached to the lever plus the three screws. How do you unattach it from the lever. On the tech page it only talks about the 3 screws that hold the striker and the 2 window channel screws, but no mention that the lever is also attched to the striker | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If I'm understanding you you want to take the striker (3 screws holding it to door) off the actuating arm coming from the handle (interior)? If so rotate it around the squared (but actually egg shaped with square corners) about 180 degrees or so. It only fits over the head of the post one way. (at least thats how mine is)
| | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | I tried that but I could not get it to rotate that far, that | | |
