1 members (69Cuda), 73 guests, and 4 robots.
Topics128,096
Posts1,056,487
Members48,444
#945444 05/24/2013 7:20 AM
My rebuild is now at the point where I am overhauling the head.
The manual says to press out the valve guides... but what is a good way to get at the angled guides? I have a 10 ton H frame press (harbor freight) but I can't figure a good way to angle the head with enough confidence to press out (and then back in) a valve guide.
Any tips?
I just used a big hammer , also a drift made to fit into the guide and stepped to fit the Outside dia.
I did the first one that way... I used a grade 8 bolt with two nuts ground down. It worked, but seemed to be very, very tight compared to the L134 motor I rebuilt last year.... so I stopped, read the manual, and it said press them out.
For $16 I can get a purpose built driver for an air hammer, and $44 for a reamer. Since I have another, early (pre-55) 235 and a 270 motor on the list I may spring for the tools... just to speed things up.
