5 members (78buckshot, ShopRag, stlcardinalsguy, Ponchogl, moparguy), 79 guests, and 2 robots.
Topics128,151
Posts1,057,000
Members48,460
#945212 05/23/2013 8:18 AM
I am in the process of swapping the diff in my 42 3/4 ton (BL). I have a 55 1/2 ton 3:90 diff & carrier that I want to put into my OE axle. I'm running the OE Muncie 4 speed with granny gear. I've bought 3:38 R&P to use in the 3:90 diff but have been unable to find a good source for new spiders and cross shaft for the GM 55T diff.
If anyone can point me towards a source for good quality spiders, I'd sure appreciate the help.
Tom
Little Egg Harbor, NJ
1942 Chevy (BL)
Ghost Rider
1942 Chevy 3/4 ton pickup, 1962 235, Offy intake, Fenton headers, Dual Carter YFs, 1984 T5
1956 Chevy 3100 Apache, 67 350SBC, Saginaw 4 speed, 69 12 bolt
When you say "new" do you mean new or are good used OK?
My Blog
Crusing in the Passing Lane
What are you doing about the two different wheel bolt patterns?
Dave:
Thanks for your reply. I spoke with Patrick Dykes in AZ yesterday. He recommended Bob Adlers Antique Auto Parts in NY. Called them today and they have a good used set at $105. I'm sending them a check today.
Ghost Rider
Good deal!
Ed, 1941-42 3/4 tons used 6 lug wheels. Basically a 1/2 ton with heaver springs.
My Blog
Tom,
"them" - you most likely spoke with "him".
He is THE expert.
I am rebuilding a GM 55T diff & carrier only, which will bolt into my OE 42 3/4 ton axle housing (has the same bolt pattern on the pumpkin). As both have 17 spline axle shafts, there will be no issues with the wheel bolt patterns. The only issue I'm aware of is the rear driveshaft will need to be lengthened about 7/8 inch, and the rear universal halves will also need to be matched.
This swap has already been completed by several guys, and I'm told it works very well. Of course..., ya never know till ya try it on your truck but, I don't expect any serious problems.
Ghost Rider
You should not have any problems with that swap.
My Blog
Tim:
I asked if it was Bob Adler on the phone and the guy on the other end said no. He also did not give me his name.
Hence the use of "them".
Ghost Rider
Dave:
Thanks.
As I am running 29.4 inch overall tire diameters, I expect the truck to drive as designed. The mod should just give me a bit better gas mileage, while taking some revs off the 1962 Chevy 235.
I have considered swapping the OE Muncie 4-speed for a Saginaw 3 speed I have on the shelf. I just thought I'd try the R&P change before I got into any trans issues. Being in south Jersey it's pretty darned flat here. Based on this, I'm not too concerned about the use of the low gear ratios in the Muncie with the 3:38 R&P
Ghost Rider
I see you have a 190SL. I have been keeping a 1961 190Db on the road for about 30 years for one of my customers.
Don't tell anyone I work on anything but Chevrolet's though. secret
My Blog
