1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 27 New Guy | | New Guy Joined: Oct 2012 Posts: 27 | Can anybody tell me what the difference is between a 3 prong and a 4 prong is????? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Oct 2012 Posts: 27 New Guy | | New Guy Joined: Oct 2012 Posts: 27 | Ah ok so I'm re wiring with a new harness I had the gen swap to 12 volts so do I need it still | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you are running a generator you need a regulator for a generator. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | There's great information in the shop manual as well as in our tech tip section.. Here's a link to the shop manual.. see section 12 | | |
