8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | This is probably a stupid question, but how the heck do I mount the vacuum advance on the distributor?? heres a picture of the vacuum advance I have. I've looked at the shop manual and flipped through Denny's pictures, and still couldn't figure it out. I bought the engine without a advance on it, so I never got to see how it should be. Vac advance picture | | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Thats exactly what I did, but nothing happens when I put vacuum to the unit. The arm can't be shoved into the advance at all. When I have the unit off the distributor, I can push the plunger in, but it pushes the clamp away from the advance, which than doesn't line up with the hole on the advance.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From whom did you get the advance unit and what is the part number?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks to me that the unit you received is not the unit in the catalog.
Call Classic Parts and tell them you received the wrong part. If that does not work, ask to speak with a technical support person and ask him/her if you may send to them a photo of the unit you received and a photo of the unit you tried to buy.
Would someone else reading these posts look at both photos and give their opinion?
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Looks like the collar is different to me,you might check that. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The back surface of the "vacuum pot" is not flat on your unit. The back surface of the original pot and the back of the unit in the Classic Parts photo is not the same as on your unit. I have bought two units from Classic Parts and they look like the photo in your catalog, not like the unit your received. I think they sent you the wrong unit.
The collar from a car is different from the collar from a truck but either one will work with the right unit (as long as you bend the vacuum line).
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | It looks like the clamp collar might interfere with the hold-down bolt on the octane selector. Maybe a clamp from a truck and a vacuum unit for a car? The entire units can be switched (with re-positioning the vacuum tube), but can the collars be switched? Hoyt | | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Tim, heres a picture of the vacuum advance without the clamp, and as far as I can tell its the right part: http://i56.tinypic.com/15f0lrr.jpgHeres just the clamp I have, Which as Hoyt pointed out, does interfere with the hold-down bolt. http://i54.tinypic.com/rssf3r.jpg | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The other Tim & Hoyt are right. Sorry about my spatial disorientation (just one type of disorientation that I suffer from). The back surface of your unit is flat.
And, you all are correct, if you use the car collar on a truck unit, the ability to rotate is affected. A truck clamp should solve your problem (as Tim and Hoyt have already posted).
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | I am having this same issue. Does anyone know where I can get a new clamp. My vacuum looks just like the one the OP had.
1950 Chevy 3600
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Or should i return the one I got and try to find one that matches the curved clamp?
1950 Chevy 3600
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Do you need the straight clamp or the curved?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | I have the curved clamp, so I think I need the straight clamp. Because I am having the same clearance issues with the new vacuum advance that was stated in the original post.
1950 Chevy 3600
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I'm going to send you a PM.
1950 Chevy 3600
1950 Chevy 3600
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Turn the clamp screw so the nut and head are switched. Screw head should face forward towards the radiator. That worked for me. Easy to get to and still let me sneak a wrench on the bolt. Set the dizzy in the hole and snug at 0. Hook up the line and get it all routed. Loosen the clamp and pull out the dizzy leaving the vacuum advance in place. Then set the timing and line up the oil pump and clamp it in place. Should work.
Steve H
