2 members (Rusty Rod, LAROKE),
103
Mod | | | Forums66 Topics128,193 Posts1,057,260 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | 1936 1.5 ton, how much oil goes in the rear U-joint plug in the back of the transmission. It should feed the center carrier U-joint also and stopped by a seal from draining into the differential. I just renwewed all the cork gaskets in the bell couplers but I don't have a clue how much oil goes in.....thanks guys. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Trans. oil is usually meant to be filled to the point where it runs out the hole when filled, that's how one knows when to stop.
| | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | Ed, this is in back of the trans. the fill plug is on top. this fill is for lubricating the U-joint that is just after the output shaft. It is enclosed when put together and connects the splined mid shaft to the mid carrier u-joint which is also enclosed. I'm talking about the entire mid assembly of a torque tube. There has to be the same setup in later trucks till about '39. | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | If your talking about the extra shaft behind the trans and before the torque tube in the 1936 1.5 ton trucks, what do they call that the mid-shaft? I tried to look that up in the on line books here and couldn't find the amount of oil or what kind of oil to use either. anybody know? I read they use to fill it with that zerk fitting on top of the rear of the trans and the used pour oil at the factory. i am sure somebody here knows what to use and how much should be put in. Because i need to know too. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | I found this out, they used 1 pound of pour oil in it, it was SAE160 in the summer and SAE90 in the winter. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | Close enough to figure out, where did you find that out? | | |
