5 members (Otto Skorzeny, Phak1, 66flea, Ridgeback, 1 invisible), 115 guests, and 0 robots.
Topics128,162
Posts1,056,944
Members48,458
When I use the right turn signal on my '65 C20, both rear lights blink, but when I use the left turn signal everything operates properly. I have pulled and cleaned the bulb and socket on the right side, but that made no difference. Any ideas?
Thanks in advance.
Check your grounds. Check your bulbs.
I think you need to look for the problem in your turn signal mechanism (steering column).
Ground.
I would say a bad ground too, likely in the one that doesn't work right.
1951 1 Ton Completed
Thanks for the replies. I finally had time to do some investigation, and found the problem was in my switch. Changed that out and now things are woking properly.
