1 members (Ponchogl), 130 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#944425 05/19/2013 10:25 PM
When pulling apart my '58 270 for a re-ring and new bearings, I had a hard time finding any kind of timing mark on the fiber cam gear. After cleaning and close inspection I found what I believe to be timing marks . Am I right in thinking the partial circle mark is the timing mark I'm looking for?
twotone #944430 05/19/2013 10:31 PM
Is that mark after the 13th tooth counting clock ways straight out from the key?
If so than that is the mark.
My Blog
twotone #944436 05/19/2013 10:42 PM
I'll have to check on that tomorrow. So, to be sure, I should count 13 teeth clock ways straight out from the key, then line up the next following gap with the timing marks on the crank gear?
twotone #944437 05/19/2013 10:45 PM
That is correct.
I did not use a straight edge just eye balled it, but I think your circle will be in that spot.
My Blog
Thanks Dave smile That's one less thing I have to sweat over.
