1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | When pulling apart my '58 270 for a re-ring and new bearings, I had a hard time finding any kind of timing mark on the fiber cam gear. After cleaning and close inspection I found what I believe to be timing marks . Am I right in thinking the partial circle mark is the timing mark I'm looking for?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Is that mark after the 13th tooth counting clock ways straight out from the key? If so than that is the mark.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I'll have to check on that tomorrow. So, to be sure, I should count 13 teeth clock ways straight out from the key, then line up the next following gap with the timing marks on the crank gear? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That is correct. I did not use a straight edge just eye balled it, but I think your circle will be in that spot.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Thanks Dave  That's one less thing I have to sweat over. | | |
