1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 52 | I have a 1965 C10 and I am upgrading to front disc brakes. I am also replacing the upper and lower control arm ball joints. How do you remove the lower ball joints? Are they pressed in? Any help would be appreciated. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, the lowers will be pressed. You should be able to rent a press from the parts store if you don't have one.
Bill Burmeister | | |
