| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | I've purchased a "vintage" Sun tach for my 1959 Chevrolet truck. On the back of tach i have two "posts", one reading "ignition sw" and one reading "trigger" this is a 12v system and has a ground wire. My question is; is the trigger the lead that goes to the distributer/coil? negative or positive? Thanks for any information. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The trigger wire goes to the - side of the coil on a neg ground system. | | | | | Joined: May 2013 Posts: 11 New Guy | | New Guy Joined: May 2013 Posts: 11 | Those old sun tachs used a special sending unit that mounted under the hood. I have one of those tachs in my '59, but no sender. | | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | I got it all hooked up and works great! I was afraid it was going to need a sending/transmiter unit but it didn't. Now i know what kind of RPM's it's turning. Thanks as always for info guys. | | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | Can you post the model number of the Sun that you have? Do you have a 235 in your '59? | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | The early (like 1950's) Sun tachs used a sending unit powered by Mercury batteries that are no longer made, with no suitable substitutes. The sender looked like a big voltage regulator with a brown Bakelite cover.
Later models eliminated the sending unit and the unobtanium batteries. Some vintage instrument restoration places used to convert the senders to solid state internal circuitry so the box would appear original from the outside. Jerry
| | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | I will stick to getting my other electrical issues taken care of before I worry about a tach for the 235! | | |
