5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#944276 05/19/2013 12:28 PM
I've purchased a "vintage" Sun tach for my 1959 Chevrolet truck. On the back of tach i have two "posts", one reading "ignition sw" and one reading "trigger" this is a 12v system and has a ground wire. My question is; is the trigger the lead that goes to the distributer/coil? negative or positive? Thanks for any information.
boomers59 #944330 05/19/2013 3:38 PM
The trigger wire goes to the - side of the coil on a neg ground system.
boomers59 #944480 05/20/2013 7:44 AM
Those old sun tachs used a special sending unit that mounted under the hood. I have one of those tachs in my '59, but no sender.
boomers59 #944899 05/21/2013 9:32 PM
I got it all hooked up and works great! I was afraid it was going to need a sending/transmiter unit but it didn't. Now i know what kind of RPM's it's turning. Thanks as always for info guys.
boomers59 #1218871 05/27/2017 4:16 AM
Can you post the model number of the Sun that you have? Do you have a 235 in your '59?
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
boomers59 #1218878 05/27/2017 5:18 AM
H Online: Content
The early (like 1950's) Sun tachs used a sending unit powered by Mercury batteries that are no longer made, with no suitable substitutes. The sender looked like a big voltage regulator with a brown Bakelite cover.
Later models eliminated the sending unit and the unobtanium batteries. Some vintage instrument restoration places used to convert the senders to solid state internal circuitry so the box would appear original from the outside.
boomers59 #1218922 05/27/2017 3:47 PM
I will stick to getting my other electrical issues taken care of before I worry about a tach for the 235!
"Calvin"
